difference between uptime and snmp uptime message
I have a difference between uptime and snmp uptime message.
This problem points itself to different Cisco Komponenenten. On router and on Switche.
failure message: The watch source value 3145251155 is greater than the threshold reference value 2508978404.
Can you tell me, what is the issue?
regards
Thomas
1 ACCEPTED SOLUTION
Re: difference between uptime and snmp uptime message
The difference seen between sysUpTime (snmp) and the time in the show version is due to snmp counters wrapping.
sysUpTime is a 32-bit counter and this mib object will wrap everyday 496 days and any differences you see between the 2 values are due to these counters.
Hello davistan,
thank you for the fast help.
regards
Thomas
233
