Webcast-Catalyst9k
Bronze
Difference between WS-X6348-RJ45V and WS-X6148-RJ45V?
Reading some CCO documentation, it was mentioned that the WS-X6348-RJ45V and WS-X6148-RJ45V
have the same performance and functions but the latter is lower in price. I have also noticed
in the module overview that FTP can be used for the WS-X6348-RJ45V. Besides this, are there
any other differences? If the WS-X6148-RJ45V's price is lower, are there any disadvantages
compared with the WS-X6348-RJ45V? Thanks in advance for any useful info.
1 REPLY
Re: Difference between WS-X6348-RJ45V and WS-X6148-RJ45V?
There are no feature differences between the two. However the 6148 uses a cost reduced version of the ASIC and hence the price is lower than the 6348. One thing you would need to keep in mind is that the 6148 would require you to use OS 7.2.2
Check the release notes below for the details.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_1982.htm
133
