Webcast-Catalyst9k
Difference!!
Whats the exact difference between "write terminal" and "write memory" commands?
After modifying the configuration,when i used "write terminal" in catalyst 6500 to save the configuration in NVRAM,i found that the config was not saved.But when i tried using "write memory" it worked fine.
Thanks in advance...
Bronze
Re: Difference!!
The 'write terminal' is just the old command for 'show running-config'.
Re: Difference!!
Can you explain it more clearly.Thanks ...
Bronze
Re: Difference!!
I hope I can explain it this way:
'write memory' or 'copy running-config startup-config' = copy the active configuration into NVRAM.
'write terminal' or 'show running-config' = copy the running configuration into the terminal screen.
'write network' or 'copy running-config tftp' = copy the active configuration to a TFTP server.
Plus some documentation:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tfr/fft204.htm#1018899
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tfr/fft201.htm#1018831
HTH.
Re: Difference!!
Thanks ....
104
