Webcast-Catalyst9k
Difference
Can anybody tell me what is the main difference between a Catalyst 3550 switch and a Catalyst 3750 switch?
Tselvan
Re: Difference
Everything:-)...The architecture of 3750 is based on our new Stackwise architecture. You can read more about it on CCO at
http://www.cisco.com/warp/customer/cc/pd/si/casi/ps5023/index.shtml
http://www.cisco.com/warp/customer/cc/pd/si/casi/ps5023/prodlit/index.shtml
Re: Difference
Thanks,krishnan
Re: Difference
Everything, basically.
The 3550 was designed with 10/100 and cascading in mind and the 3750 with 10/100/1000 and stacking in mind. The 3550 is built on a central switching ASIC and the 3750 is built on a number of ASICs connected to a ring.
From a user point of view, i guess the main difference is "x10".
-A
Re: Difference
While other 3550 series models only support 10/100 the 3550-12G & 3550-12T series are exceptions and support 10/100/1000.
Rajesh
101
