06-24-2002 05:16 AM - edited 03-01-2019 10:22 PM
hello,
Can any one state the basic differences between the a gigabit uplink port on the 65xx switch's supervisory engine and a normal gigabit port on a switching module installed in the switch.
-- can it be used to pass traffic between the LAN segment --- to/from --- f/w --- the edge router?
-- what are limitation or advantages to using the uplink port?
greg
06-24-2002 05:30 AM
Basically, both ports act as normal gigabit switch ports.
However, there are some differences in QoS features, connection to switching fabric, subscription, etc. For the most part, it does not make a difference which port you use unless you are using advance features such as QoS and high bandwidth.
06-25-2002 10:28 AM
Thanks for the information. That was just what I needed to know.
Greg
