Community Member
Different between flow and aggregate
Microflow policers are defined within the policy map configuration, just like per-interface aggregate policers. In the example below, every flow from host coming into VLAN 2 will be policed to 100 Kbps. All traffic from will be policed to 500 Kbps aggregate. VLAN 2 includes interfaces fa4/11 and fa4/12.
mls qos
access-list 1 permit
class-map match-all host_2_2
match access-group 1
policy-map host
class host_2_2
police flow 100000 2000 conform-action transmit exceed-action
police 500000 2000 2000 conform-action transmit exceed-action drop
interface fa4/11
mls qos vlan-based
interface fa4/12
mls qos vlan-based
interface vlan 2
service-policy input host
What is the major differences between flow and aggregate policers?
Re: Different between flow and aggregate
QoS applies the bandwidth limits specified in an aggregate policer cumulatively to all flows in matched traffic. You can create up to 1023 aggregate policers. You can create two kinds of aggregate policer named and per-interface.
QoS applies the bandwidth limit specified in a microflow policer separately to each flow in matched traffic.
* You can create microflow policers with up to 63 different rate and burst parameter combinations.
* You create microflow policers in a policy map class with the police flow command.
* You can microflow police IP, IPX, and MAC-Layer traffic.
During microflow policing, QoS aggregates MAC-Layer flows that have the same source and destination MAC-Layer addresses. By default, microflow policers only affect traffic routed by the MSFC.
