Community Member
differnet vlan same subnet
i have a cisco switch,i create two vlans,vlan1 and vlan2
now i connect PC A to vlan1,PC B to vlan2
i know PC A and PC B must be in different subnets.
but if PC A and PC B in same subnet,what will occur? and if i ping from PC A to PC B ,can they reacheable?
another question:
i create two pvlans in switch,one pvid is 1,and one pvid is 2
now i connect PC A to pvlan 1,PC B to pvlan 2,
i think PC A and PC B can be in same subnet,and PC A can not access PC B
am i right?
Re: differnet vlan same subnet
For your first question, answer is no unless if you have a router to route/bridge vlans.
For your second question, if you are planning to have layer isolation between PC A and PC B, you do not have to create 2 PVLANs. Just create one main PVLAN and have the ports connecting to PC A and PC B in a isolated VLAN http://www.cisco.com/warp/public/473/90.shtml
By the way what switch do you have?
Community Member
so PCs in different Vlans can be in same subent?
100
