Community Member
dilaer profiles with async dial-in over PRI ISDN
I have a 5350 RAS server set up with modems and ISDN Pri interface. I want to use the RAS to dial-in using both async modem interfaces and ISDN routers. I can get both of these working fine but not both at the same time. Is there something missing from the config.
Bare bones of config is as follows:-
interface Serial3/0:15
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-net5
isdn incoming-voice modem
no fair-queue
ppp authentication chap
interface Dialer3
ip address x.x.x.x 255.0.0.0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name XXX
dialer idle-timeout 60
dialer-group 1
no peer default ip address
ppp authentication chap xxxxx
ppp authorization xxxxxxx
interface Dialer73
description xxxxxx
ip address xxxx 255.255.255.0
encapsulation ppp
dialer pool 1
dialer remote-name xxxxxx
dialer-group 1
no cdp enable
interface Group-Async0
ip unnumbered Loopback0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer in-band
dialer idle-timeout 300
dialer-group 1
async mode interactive
no fair-queue
group-range 1/00 1/59
If I use a pc and dial-in using a modem link it works ok to the group-async0. However if I then try to do an ISDN link to interface dialer 73 it wont let me in.
I get an “ISDN Se3/0:1: Incoming call rejected, unbindable”
With no async dial-in ongoing the ISDN dial-in works ok to , for example interface dialer 73.
Any guidance on this matter would be appreciated!!
John Davies
1 REPLY
Bronze
Re: dilaer profiles with async dial-in over PRI ISDN
Since you have included "isdn incoming-voice modem" command only Async calls will be diverted to the modem and you can use ISDN at the same , I see some IP address miss match with the dialer profile.If you use the same IP address pool it has to work fine .You can use "peer default ip address pool XXXX" for dynamically asigning IP address.
for referance use this link
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094557.shtml
76
