03-20-2003 12:08 PM - edited 03-02-2019 06:01 AM
I noticed that our routers are allowing telnet from the outside interface. The routers in question are a 3640 and 2600 series. How do I disable telnet for just the outside interface?
03-20-2003 12:20 PM
What do you mean with outside interface?
You can have a ACL on you vty and allow only specific ip addresses. Thats done with an access list like:
access-list 20 permit 10.0.0.0 0.0.0.255
router(config)#line vty 0 4
router(config-line)#access-class 20
Hope that helps you
Roger
03-20-2003 12:34 PM
I see. So I could create the ACL to allow telnet to the routers from only the specified internal network.
Thank you.
03-20-2003 12:45 PM
Exactly, but you always have to pay attention when you configure it if you are
connectet to it with telnet so you don't look you out.
Ciao
Roger
