Webcast-Catalyst9k
Disable Wireless NIC
Do anyone know of any script that tweak the registry to disable the wireless NIC when both the wired and wireless NIC is detected.
In situation where both the wired and wireless NIC is enabled, we want a script that alter the registry key in XP to disable the wireless NIC and left the wired NIC alone.
Pls advise and thanks.
1 REPLY
Re: Disable Wireless NIC
have you asked this on a Microsoft forum? You may have better luck getting an answer.
278
