Disabling IP MLS on 6509 SWitch and MSFC
Hi all.
I searched the discusions and didn't come up with the solution to my problem, so here it is.
I have a situation where I wish to disable MLS (only running IP so need to disable IP MLS) on a 6509 switch and associated MSFC. Is it possible? And does someone know how?
Rob.
1 REPLY
Re: Disabling IP MLS on 6509 SWitch and MSFC
Is there any specific reason you want to disable MLS? If you have a Sup1a with an MSFC, you can do it by issuing "no mls ip" in configuration mode in the MSFC
http://www.cisco.com/warp/public/473/35.html#readingshmls
If you have a Sup2/MSFC2, we use CEF based MLS and cannot be disabled
99
