03-11-2003 11:36 PM - edited 03-02-2019 05:47 AM
I have a Cisco AS53500 with IOS 12.2(2)XB8 and I would like to disable sending the linkup and linkdown traps for my ISDN PRI line. I have put the "no snmp trap link-source" command on the Serial3/0:15 interface but traps are still sent.
Any help would be greatly appreciated.
03-12-2003 05:00 AM
The command you are looking for is:
no snmp-server enable traps snmp linkup linkdown
03-12-2003 06:11 AM
But this will disable the sending of snmp-traps at all...I would like to receive traps for serial interfaces.
03-13-2003 12:17 AM
In this case you need to configure globally "snmp-server enable traps snmp" to enable the sending of SNMP linkUp and linkDown traps, and after that to disable the sending of this traps on an interface basis with the command "no snmp trap link-status".
03-13-2003 12:46 AM
Yes,
the problem is that the command is configured on the serial3/0:15 interface but traps are still sent
