discards on sc0 interface
Does anyone know what might be causing a large amount of discards to amount on a Sc0 interface on 6500,
cheers in advance
Re: discards on sc0 interface
hi
AFAIK few possible reasons for the discards are to free up the buffer space,on during heavy traffic load conditions frames are tend to be discarded,if its of VLAN discard frames then the reason is due to the CFI(canonical format identifier)set.
For more info do refer this link..
http://www.cisco.com/warp/public/473/53.shtml
regds
If the sc0 interface receives a packet that does not match the sc0's mac address, for example, the packet is marked as a discard.
You may want to SPAN the SC0 interface to see if it is receiving any unusual traffic.
switch(enable) set span sc0 ?
Destination module and port numbers
HTH,
Bobby
159
