DLSW - Border Peers and Peer Groups
lkhan
We have DLSW using Border peers. What I need to know is - if I was to add another router (external router) to peer with our DLSW network does this router need to be part of a peer group or can I configure a local peer statement and a remote peer statement pointing to our Border peer:
dlsw local-peer peer-id 1.1.1.1 prom
dlsw remote-peer 0 tcp 2.2.2.2 (our border peer)
or
dlsw local-peer peer-id 1.1.1.1 group 1 border prom
so, do I need to create a group just for this one router?
thanks in advance
rsissons
Level 5
Level 5
If you want to peer to a router which is a border peer then, either this router must be in the same peer group as the border router, or it must itself be a border router in a different peer group.
In other words, you do need to create a new group for the new router if you do not want to add it to an existing group.
