DLSW - SNA Protocol Issue
ganeshp
My client was using IBM router at remote and connecting to IBM router at HQ with WAN line speed of 64kbps. Running OSPF. The application is running on SNA protocol.Remote branch will access the "HOST - Mainframe" at HQ.
After the migration to Cisco routers the customer complain the accessing to the "HOST' became slower.
Iniatially when on IBM platform the network design was very straight forward. The remote branch directly connected to Frame-relay cloud to HQ with on PVC.
Now there is 2 units of 7206 Cisco routers at HQ for redundancy purpose.
Branch remain with frame-relay 64 kbps but using 2 logical sub interface with different PVC to connect to the 2 units of 7206 routers at HQ.
Since running on OSPF routing protocol, IP packets can loadbalance via the both PVC but how about the SNA protocol?
Will there be any issue on the amount of bandwidth being use for SNA application after the migration since the remote branch will only connect to one of the router at one point of time using DLSW to access the HOST.
rabeder
hi,
i assume you use dlsw+ to transport sna over the ip-cloud - right?
if yes:
are you using backup-dlsw peer?
are the dlsw peer in the hq on the fr-routers?
do you use on dlsw-peer on on 7206 and another peer at the other 7206 ?
hi,
Below is my remote config. Is there any issue with this config?
dlsw local-peer peer-id 141.1.20.1
dlsw remote-peer 0 tcp 141.1.243.1
dlsw remote-peer 0 tcp 141.1.243.3 backup-peer 141.1.243.1 linger 3
dlsw icanreach sap 0 4 8 C
dlsw bridge-group 1
interface FastEthernet0/0
ip address 141.1.20.1 255.255.255.0
no ip redirects
ip route-cache flow
ip ospf authentication-key 7 10441917
speed 100
full-duplex
bridge-group 1
interface Serial0/0
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
cdp enable
frame-relay lmi-type ansi
interface Serial0/0.899 point-to-point
description PVC to HQ 7206_2
bandwidth 64
ip address 10.6.2.10 255.255.255.252
ip ospf authentication-key 7 030E4B05
ip ospf network point-to-point
frame-relay interface-dlci 899
interface Serial0/0.900 point-to-point
description PVC to HQ 7206_1
bandwidth 64
ip address 10.6.1.10 255.255.255.252
ip ospf authentication-key 7 000E0308
frame-relay interface-dlci 900
