DLSW Strange MAC Addresses *HELP*
Hello all,
I have two PCs connected over a DLSW dynamic peer (or any old peer). The MAC address of the IBM-PC is 00-01-03-86-04-34
(but in the DLSW reachability command it is reported as 0080.c061.202c) and the compaq-laptop MAC address is 00-10-a4-00-65-c1 (again, the DLSW reachability command reports it as 0008.2500.a683)
Can anyone explain why this is? The DLSW peers are peering off a loopback address off each router but loopbacks do not have MACs do they? If so, I cant find these two MAC addresses that the DLSW command is reporting.
Many thx indeed.
Ken
rtr3>sh dlsw rea
DLSw Local MAC address reachability cache list
Mac Addr status Loc. port rif
0080.c061.202c FOUND LOCAL TBridge-0DD --no rif--
DLSw Remote MAC address reachability cache list
Mac Addr status Loc. peer
0008.2500.a683 FOUND REMOTE 30.1.3.1(2065) max-lf(1500)
DLSw Local NetBIOS Name reachability cache list
NetBIOS Name status Loc. port rif
IBM-LAPTOP FOUND LOCAL TBridge-0DD --no rif--
DLSw Remote NetBIOS Name reachability cache list
NetBIOS Name status Loc. peer
COMPAQ-LAPTOP FOUND REMOTE 30.1.3.1(2065) max-lf(1500)
rtr3>
1 REPLY
Silver
Re: DLSW Strange MAC Addresses *HELP*
Hi Ken,
this is simple to explain:
entries in show dlsw reach appear in non-canonical format as opposed to canonical format as on Ethernet or in the output of show bridge.
0080.c061.202c is the non-canonical format of 00-01-03-86-04-34
0008.2500.a683 is the non-canonical format of 00-10-a4-00-65-c1
So, ethernet attached devices appear with their MAC addresses translated while Token-Ring attached devices don't.
Cisco has a Bitswapping Tool (available to registered users) to translate between canonical and non-canonical MAC addresses:
http://www.cisco.com/cgi-bin/Support/Bitswap/bitswap.pl
Hope this helps
106
