01-08-2003 08:43 AM - edited 03-02-2019 04:01 AM
Will it work out of the box with no configuration? I cannot find anything in documentation that says whether it will or not. We are trying to use 2 new switches out of the box and we get a link light for all connected devices, but none are actually connected to the network.
Please Help!
thanks
01-08-2003 09:08 AM
Yes, it should work as a flat, one-VLAN, Layer 2 switch, right out of the box.
Management will not be available until you add an IP address (mask, gateway, etc) via the console.
Scott
01-08-2003 09:13 AM
If you are having DHCP/Login issues, make sure you enable port-fast on the ports
01-08-2003 09:37 AM
Yes it should work as out of box,- But it always good to enable basic things on the switch, like mgmt ip, portfast on the ports etc..
