Does a WS-X4448-GB-RJ45 work in a 4003 chassis with Sup 1 module
I am trying ot find if I can use WS-X4448-GB-RJ45 in 4003 chassis that has WS-X4015 (Sup 1) module? Looking at the dynamic configuration tool, it only lists the 24 port module and the 48 port version.
Gary Gladney
1 REPLY
Re: Does a WS-X4448-GB-RJ45 work in a 4003 chassis with Sup 1 mo
Sup1 is WS-X4012. Yes WS-X4448-GB-RJ45 will work in it as long as you are running minimum required CAT OS 7.x. 7.6(6) is the latest in 7.x
111
