Community Member
Does BPDU-Guard cause an STP re-calculation?
I am enabling this feature on my switches and understand it only affects portfast enabled ports but are there any spanning-tree convergence issues when I issue this command on a switch? I don't want to bring down my lan from an stp perspective.
Any replies would be appreciated.
-Ken
1 ACCEPTED SOLUTION
Re: Does BPDU-Guard cause an STP re-calculation?
Ken,
I didn't think it would cause any STP reconvergence. I enabled it in a lab switch and didn't see any issues. Looks like you can safely turn on the feature.
HTH,
Sundar
Community Member
Are you doing this in global or on the interface level? I have gone thought this for a network and did not have any STP issues at all.
Ken,
HTH,
Sundar
123
