Community Member
Does CISCO already provide or will provide IDU for Campus Manager 3.1???
CM of CWLMS 2.0 don't support 3550 series and 2950 series, so the applications under CM don't work correctly. I found the solution here, it is upgrading to 2.1. if that is the only way to solve the problem? Does cisco already have IDU for CM 3.1( I just found IDU for RME 3.3), or cisco have the plan to provide IDU for CM 3.1 later??
We still have some customers who are still using works2000 for HP-US/AIX, I know CISCO didn't ship it any more, so if CISCO have plan to solve the same problem of above??? Anyway, it is not so easy to exchange to CWLMS 2.1.
1 REPLY
Blue
Re: Does CISCO already provide or will provide IDU for Campus Ma
There is no IDU for CM 3.1, it's only available for CM 3.2. So, you would need to upgrade to CM 3.2 for the support of the above switches. As for HP-UX/AIX, the user need to migrate to WIndows or Solaris platform to get new device support as well.
84
