Does icmp redirect work with policy based route
Setup:
R1 and R2 on same ip net.
On R1 policy based route is configured with R2 as next hop.
Will R1 send icmp redirect (to use R2 instead) to those hosts that match the policy based routing ?
Thanks.
Gert Schaarup
1 ACCEPTED SOLUTION
Purple
Re: Does icmp redirect work with policy based route
HI Gert,
The answer to your question is yes. I have verified this in a lab previously. As long as all the conditions for ICMP redirect have been met (source address on same net, best gateway on same net) then ICMP redirects are sent regardless of whether PBR or normal routing is being used.
Hope that helps - pls rate the post if it does.
Paresh
1 REPLY
Purple
HI Gert,
Paresh
406
