Does "dual power supply" mean "redundant power supply"?
Does Cisco7301 "dual power supply" mean "redundant power supply"?
If unplug one power socket, 7301 continues operating?
whiteside998
Hi misokatsu nagoya
Yes, Dual AC or even DC power supply, will mean that if one of the supplies fails the device we keep operating
in this case it is fairly normal practice to connect each supply to a PDU's connected to different power Circuit.
hopefully this helps
regards,
Thanks for the info !
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
On a 7301, I believe it does act as a redundant power supply, and this is often true for many Cisco devices with dual power supplies, but there can be exceptions.  For example, on the 6500 chassis, you might use dual power supplies in combined mode, i.e. failure of a power supply would leave the chassis short of necessary power.  The 3560X/3750X might also have insufficient power if a power supply fails when running on two (this issue may arise when using PoE).
