Domain suffix problem with DHCP
I have problem with getting a "domain suffix" to a XP
clint using DHCP (Win2K)
When we connect the client direct to the LAN, there is no problem getting the right TCP/IP configuration.
But when we use AS5200 and dialing the network via modem, we get every configuration (IP,Wins,DNS) except the Domain suffix.
We have tried with ip domain-name and no result.
Could please some one help me with this ?
Configuations on the AS5200 as follow.
version 12.0
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime
service password-encryption
hostname as5200
logging buffered 1000000 debugging
aaa new-model
aaa authentication login default tacacs+ local
aaa authentication login dialout tacacs+ local
aaa authentication enable default tacacs+ enable
aaa authentication ppp default tacacs+
aaa authentication ppp dialout tacacs+
aaa authorization exec default tacacs+
aaa accounting exec default start-stop tacacs+
aaa accounting commands 15 default start-stop tacacs+
aaa accounting network default start-stop tacacs+
aaa accounting connection default start-stop tacacs+
aaa accounting system default start-stop tacacs+
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXX
username XXXXX password 7 XXXXXXXXXXXXXXXX
ip subnet-zero
no ip domain-lookup
ip address-pool dhcp-proxy-client
ip dhcp-server XXX.XXX.XXX.XXX
async-bootp nbns-server XXX.XXX.XXX.XXX
async-bootp dns-server XXX.XXX.XXX.XXX
isdn switch-type primary-net5
clock timezone MET 1
clock summer-time MET recurring last Sun Mar 2:00 last Sun Oct 3:00
controller E1 0
framing NO-CRC4
clock source line primary
pri-group timeslots 1-31
controller E1 1
shutdown
clock source line secondary
buffers small permanent 75
buffers middle permanent 50
buffers big permanent 100
buffers Serial0:0 permanent 25
interface Ethernet0
ip address XXX.XXX.XXX.XXX 255.255.255.0
no ip directed-broadcast
no ip route-cache
no ip mroute-cache
interface Serial0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Serial1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Serial0:15
ip access-group 101 in
encapsulation ppp
no ip route-cache
dialer idle-timeout 300
(Excluded the dialer map)
dialer-group 1
isdn incoming-voice modem
no peer default ip address
no fair-queue
no cdp enable
ppp authentication chap pap
ppp multilink
interface Group-Async1
ip unnumbered Ethernet0
encapsulation ppp
no ip route-cache
no ip mroute-cache
async default routing
async dynamic address
async mode interactive
peer default ip address dhcp
no cdp enable
ppp authentication ms-chap chap pap
group-range 1 36
interface Dialer0
no ip address
no ip route-cache
no ip mroute-cache
dialer-group 1
no cdp enable
interface Dialer1
no ip address
no ip route-cache
no ip mroute-cache
router ospf 1
summary-address XXX.XXX.XXX.XXX 255.255.255.0
redistribute static subnets
network 0.0.0.0 255.255.255.255 area 0
ip classless
(Excluded ip route command)
(Excluded access-lists)
tacacs-server host XXX.XXX.XXX.XXX
tacacs-server timeout 30
tacacs-server key XXXXXXXXXXX
snmp-server community public RO
snmp-server community works RW
line con 0
transport input none
line 1 36
session-timeout 15
no exec
autoselect ppp
refuse-message ^CCC[!NMM!] Inga modem lediga^C
modem InOut
modem autoconfigure discovery
rotary 1
transport input all
line aux 0
line vty 0 4
password XXXXXXXXXXXXXXXX
history size 25
ntp clock-period XXXXXXXXX
ntp server XXXXXXXXXXXXX
end
  • Other Network Infrastructure Subjects
1 REPLY
VIP Purple
Re: Domain suffix problem with DHCP
the config looks ok, my guess is this is more an issue with the XP clients. I did a search in the MS Knowledge Base and came up with these two issues, not sure if this applies to you:
http://support.microsoft.com/default.aspx?scid=kb;en-us;317288&Product=winxp
http://support.microsoft.com/default.aspx?scid=kb;en-us;299062&Product=winxp
Georg
247
