Community Member
Dot1q Trunk Issue
We have 50 2950 edge switches all trunked to a Layer 3 6509 .
The trunks are dot1q trunks all running latest software releases .
Issue relates to not being able to ping the switch, while the trunk is showing up on the 6509 and CDP info is visable .
Bring the trunk down and up again and service is restored .
Any ideas?
Re: Dot1q Trunk Issue
do you allow your managment vlan across the trunks?
Community Member
Management Vlan is allowed down allow the trunk . The issue was seen on three switches last night , no other instances since.
Community Member
I have had similar experiences with the same setup. We have 2950's downstream from a 6506 with the MSFC card in it. Every once in a while the switch seems to lose its way to the downstream 2950's. To fix it I have had to get into the MSFC and ping from there to the downstream switch. As soon as I log back into the switch part of the 6500, I am able to ping again. It is like it discovered the router all over again.
Very strange.
Please check the following:
Is your native vlan set to the same vlan-ID on both ends?
Does this setting match with your default vlan?
With 802.1q, the native vlan is transmitted untagged. Frames may not be recognized correctly when a tagged frame is received, and an untagged frame was expected vice-versa. This can result in losing connections in the way that is described.
It is good practice to set your default vlan as native.
Community Member
Regarding the "native VLAN transmitted untagged" - I much prefer to have
*all*VLANs tagged, which is possible in recent versions of IOS for 3550
and some other switches ("vlan dot1q tag native"). I believe I also read that
this will cause untagged packets entering a dot1q trunk port to be dropped,
which is a good thing.
