Double Uplink between two catalysts 3550 for failover
how can I do a configuration where I would have two switches 3550 with two uplinks between them for failover, but in case that the main uplink starts flapping I would prefer that second one stays. I mean failover but without recovery. Can you help me on that?
Thanks.
Jorge
Re: Double Uplink between two catalysts 3550 for failover
I would use a EtherChannel, here is a link for you.
http://www.cisco.com/en/US/partner/products/hw/switches/ps646/products_configuration_guide_chapter09186a008031ffba.html
If you need to have other VLANs than VLAN 1 going over the link, simply make the link a trunk.
This is in addion to setting up the ehterchannel.
http://www.cisco.com/en/US/partner/products/hw/switches/ps646/products_configuration_guide_chapter09186a008031fe94.html#wp1100024
Hope this helps.
But how do I then enforce that all traffic goes via one of the Uplinks and the second one is ONLY for failover?
Jorge
Couldn't you connect two Uplinks. Then, spanning tree should put one of the ports in a blocking state and the other in a forwarding state. That way, if the first link goes down, SPanning Tree would recalculate and change the link to forwarding.
211
