DRAM and Flash on C3640
Hello
Does anybody know that the DRAM and Flash on C3640 can be used on other serial cisco routers such as C2600 ?Thank you in advance
Silver
Re: DRAM and Flash on C3640
No the 3640 uses standard 72 pin SIMMS whilst the 2600's use 100 pin 3.3v SODIMS.
I just mean that the DRAM and Flash can use on another serial platform excluding c3600?
Flash can be used with 2600, but be careful if you are going the reverse (2600 to a 3600) when using non-Cisco memory as the 3600s have a set limit as to how large the storage space can be. Not sure if these sticks can be used in other platforms.
103
