DRAM split on 2610
Is there an ios command that will allow me to see the memory split on a router without having to visit site ?
Silver
Re: DRAM split on 2610
memory-size iomem xx ' the xx is the percentage of Dram you want to allocate to io memory. You must reload the router for this parameter to take affect.
unfortunately For the 2600, the tool is not available. Its available for the 3600.
http://www.cisco.com/warp/public/63/simm_config_3620_3640.html
Silver
I have to disagre with the last post I have 2600's running 12.0 code that support this option .
I decided to try the procedure documented in the previous email anyway but the rommon ver I have on my router is 11.3(2)XA4. Is there a way of getting the address of dram_config as 11.3(2)XA4 is not in the list.
137
