Dribble Bit Error - Define & Cause ?
I know that dribble bit error is the error caused by a "slightly long packet". Questions are :
1. Is it enough to define a dribble bit error ?
2. What are the causes for such errors ?
3. Any good write up on this ?
Nadeem
1 REPLY
Re: Dribble Bit Error - Define & Cause ?
This could point to a problem where the InterPacket Gap (IPG) is too small or non-existent such that 2 frames join together. The IPG is the fixed time gap between Ethernet Frames. This is set at 9.6 microseconds.This frame will still be processed.
1425
