ds1-ds2 running hsrp)
ps examine the design in the attachment;sw1 connected to sw2 via stack &sw1 connected to ds1 also sw2 connected to ds2.(ds1-ds2 running hsrp).this a good physical link or what?what is ur suggestion?this will work proprly?
10xs
Blue
Re: ds1-ds2 running hsrp)
yes, this design will work.
you can also use the HSRP to perform load balancing between the MSFCs/routers by alternating HSRP priorities of VLANs.
also, be sure to verify your SpanningTree config; rootBridge; BPDU guard/filter; rootGuard, etc...
see this link for more HSRP info:
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00801cdf27.html
see this link for more STP info:
http://www.cisco.com/en/US/tech/tk389/tk621/tsd_technology_support_protocol_home.html
Simple config(by alternating HSRP priorities of VLANs)please!
10xs
ds1
interface Ethernet0
ip address 171.16.6.5 255.255.255.0
standby 1 preempt
standby 1 ip 171.16.6.100
standby 1 track Serial0
standby 2 preempt
standby 2 ip 171.16.6.200
standby 2 track interface
standby 2 priority 95
ds2
Current configuration:
interface Ethernet0
ip address 171.16.6.6 255.255.255.0
standby 1 preempt
standby 1 priority 95
standby 2 preempt
you can configure like this
regards
Devang
here you can have any interface tracking which you would like to track... as i tracking serial 0 on above configuration... you can use as per your requirement...
regards
Devang
Blue
router1:
interface VLAN 10
standby 10 ip 10.10.1.1
standby 10 priority 105
standby 10 preempt
interface VLAN 15
standby 20 ip 10.15.1.1
standby 20 priority 110
standby 20 preempt
switch2:
interface VLAN 10
standby 10 priority 110
standby 10 preempt
interface VLAN 15
standby 20 priority 105
standby 20 preempt
this very basic hsrp config will provide the following:
switch1:
* provides primary routing for VLAN 15
* provides backup routing for VLAN 10
switch2:
* provides primary routing for VLAN 10
* provides backup routing for VLAN 15
you should also look into HSRP Tracking to track specific interfaces for up/down so HSRP can adjust accordingly. (document link previously provided)
i also like to set priorities on all hsrp groups above the default 100. (kind of a failsafe incase someone else adds an hsrp config to a specific group without setting a priority; keeps the new hsrp addition from becoming active accidentally)
i also like to keep hsrp priorities 5 points apart. so if you use Tracking (recommended) the hsrp priorities will not become the same as they would if they were 10 points apart. (tracking by default lowers the tracked interface HSRP priority by 10 when tracking discovers a down interface)
any further input from others on hsrp best practices is welcome.
Hi gpulos!
10xs for ur reply.great explanation!
Hi gpulos !
if i use ur config.what about the route bridge primary.and route bridge secondary on the 2 distribuation .i have 50 vlans.
Simple config ps!look i know the command:
spaning tree vlan x primary(ds1)
spaning tree vlan x secondary(ds2)
10xs
Blue
can you supply the configuration(s) of the switches?
not fully clear of your query. are you asking about spanningTree config and how to setup rootBridge and backup rootBridge properly?
yes it will work properly and you can also use the different HSRP standby group configuration in order to acive the optimum utilisation of you resources...
or you can say the loadbalancing with HSRP...
regards
Devang
140
