Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DSL and PIX 515
Is it possible to plug you dsl modem directly into the outside interface on the PIX? Then I would use NAT or PAT for the LAN stations wanting access to the internet.
Also, do you need a seperate public ip for you internet, vpn, and mail connection or can they all use the same ip.
1 REPLY
Re: DSL and PIX 515
You mean to say you want to connect the ethernet port of DSL modem to outside ethernet port of PIX right?
YES..only if the dsl line is configured for PPPoE.
PIX now can act as PPPoE client on outside interface. So pl. visit following url for config, debug and more on that
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/config/pixclnt.htm
83
