dsl settings
Can anyone please tell me how the isp's use the vc and vpi settings, and where they are assigned etc ?
Re: dsl settings
can anyone help !!!!
Re: dsl settings
The VCI & VPI settings are issued by the ISP
EX] 0 35
You will need to setup the atm interface.
What router are you using?
Purple
Re: dsl settings
On the ATM link to your router, the ISP is free to assign pretty much any VPI/VCI, since they are locally significant to the link. Typically, they will use something like VPI 1 and VCI 32, for the sake of consistency.
Within the ISP's network, they will usually run a protocol such as PNNI, which will dynamically assign VPIs and VCIs on trunk interfaces.
Hope that helps - pls rate the post if it does.
Paresh
Re: dsl settings
Hi there, thx for your reply, I would like to know why some and how isp's can use the same vci's etc, what are they used for and what assigns them, is it a large router etc ?and why do they use them !!
117
