For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Dual Internet T1 help
Can anyone point me in the right direction. I need to add a second Internet T1 line to my company. How can I bundle these two T1's on one router so they can both share the load without doing BGP?.
  • Other Network Infrastructure Subjects
Bronze
Re: Dual Internet T1 help
The easiest way is to add two default routes on your router (one per T1) and on each serial interface add the command "no ip route-cache" -> this enables per-packet load balancing. You will also need to ask you ISP enable per-packet load-balancing on their end also and to add two routes for your network block over each T1.
e.g.
ip route 0.0.0.0 0.0.0.0 x.x.x.x (T1 #1)
ip route 0.0.0.0 0.0.0.0 y.y.y.y (T1 #2)
int s0
no ip route-cache
int s1
no ip route-cache
Alternately the command ip load-sharing per-packet
does the same thing as no ip route-cache.
Bronze
You can also use MultiLink PPP to create a single virtual link out of several links, the two T1's in your case. This is only possible if both your T1's terminate at the same remote router (which first requires that they go to the same ISP). Both you and your ISP then configure a MultiLink PPP bundle.
86
