Community Member
Dual ISIS routing (IP and CLNS)
What is going on here?
I have a ring of 4 routers running all ISIS in a dual environment, they are all L2 routers and have formed a L2 adjacency with their directly connected neighbor. IP routing is working fine and I can ping all routers.
If I do a clns ping I can only ping a router that I have a direct adjaceny with. I would have expected to have full clns routing within the L2 area, which I have for IP.
I have tested this with the following IOS
122-7c and 122-17a
Please help!
Community Member
Re: Dual ISIS routing (IP and CLNS)
Kevin:
We would need to see the entries in the CLNS routing table and the result from a couple of pings/trace to start to narrow down the problem.
I suggest that you open a case w/the TAC so that you can work w/someone real-time and get this resolved faster.
Regards. Alvaro.
Gold
Check your email. :-)
Russ.W
100
