Webcast-Catalyst9k
duplex problem
Please explain me why switch make the collision if we setup link be half-duplex ? (not only hub can make the collision ?)
1 REPLY
Re: duplex problem
That's the way ethernet work in half duplex. You cannot transmit or receive at the same time. If two machines try to send at the same time collision occurs and all machine back off for some time before sending the frames again.
Please go to google and find out the ethernet operation links.
HTH, please rate if it does.
-amit singh
100
