E-Mail Attachment problems with VLANs
aherringiii
User A was moved to a over to a VLAN on our network yesterday, which contains (6) 2950 switches trunked together via the GigabitEthernet ports, routing through a 2801, through a firewall, to a 2600 router and out to the Internet now he's having problems sending E-mail's with attachments larger than 40K. User A can get to the internet fine and use e-mail without attachments, but when sending e-mails with attachments, whether the service is web-based or POP3, the SMTP message time's out.
When
When User A is on the native VLAN he has no problems with E-mail attachments. MTU on both the router and firewall are at default 1500. Even if it was a MTU issue, which I don't think it is, that would effect the native VLAN users as well, or so I would think. Could this be an MSS problem?
We're using an Internet Web Filter so we do use SPAN to monitor ports
mheusinger
Level 10
Level 10
the native VLAN does not use a dot1Q encapsulation, so it could be a MTU/MSS issue. Can you set the mtu on the trunkports to higher values f.e. 1600?
You could also check with ping -f -l 1472 what the path MTU for the client to the firewall is.
Martin
C:\Documents and Settings\Administrator>ping -f -l 1472 www.yahoo.com
Pinging www.yahoo.akadns.net [216.109.117.108] with 1472 bytes of data:
Reply from 216.109.117.108: bytes=1472 time=39ms TTL=53
Reply from 216.109.117.108: bytes=1472 time=47ms TTL=53
Reply from 216.109.117.108: bytes=1472 time=37ms TTL=53
Ping statistics for 216.109.117.108:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 47ms, Average = 40ms
Looks ok.
