E-Mail Attachment problems with VLANs
User A was moved to a over to a VLAN on our network yesterday, which contains (6) 2950 switches trunked together via the GigabitEthernet ports, routing through a 2801, through a firewall, to a 2600 router and out to the Internet now he's having problems sending E-mail's with attachments larger than 40K. User A can get to the internet fine and use e-mail without attachments, but when sending e-mails with attachments, whether the service is web-based or POP3, the SMTP message time's out.
When
When User A is on the native VLAN he has no problems with E-mail attachments. MTU on both the router and firewall are at default 1500. Even if it was a MTU issue, which I don't think it is, that would effect the native VLAN users as well, or so I would think. Could this be an MSS problem?
We're using an Internet Web Filter so we do use SPAN to monitor ports
  • Other Network Infrastructure Subjects
Re: E-Mail Attachment problems with VLANs
the native VLAN does not use a dot1Q encapsulation, so it could be a MTU/MSS issue. Can you set the mtu on the trunkports to higher values f.e. 1600?
You could also check with ping -f -l 1472 what the path MTU for the client to the firewall is.
Martin
C:\Documents and Settings\Administrator>ping -f -l 1472 www.yahoo.com
Pinging www.yahoo.akadns.net [216.109.117.108] with 1472 bytes of data:
Reply from 216.109.117.108: bytes=1472 time=39ms TTL=53
Reply from 216.109.117.108: bytes=1472 time=47ms TTL=53
Reply from 216.109.117.108: bytes=1472 time=37ms TTL=53
Ping statistics for 216.109.117.108:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 47ms, Average = 40ms
Looks ok.
214
