E1 G703 problem
I have an issue installing any single port G703 E1 card (VWIC-1MFT-E1-G703) into a 2620XM.
The 2620 already has an identical card (sinle port G703 E1 card) in the WAN slot 0 (Right hand side slot as you look at rear of router).
If I install an additional G703 (ive tried 2 new ones) in the second avaialble WAN slot, I cant see the card. sh diag does not see the card installed, only the origianl is detected.
To prove that the slot is ok, I teste with a standard E1 card in the second WAN slot and it works fine, sh diag sees it immediately. So im confident the slot is ok, and the cards are ok as they are new.
Ive tried running setup again and re-configuring the int's and controllers with both cards in, no luck.
My question, does the 2602XM only support a single G703 card (or a single dual port G703 card) at any one time?
Or is ther some further troubleshooting I could try?
Simon
VIP Purple
Re: E1 G703 problem
just to be sure, do you have at least IOS version 12.2(8)T running on your 2600XM ?
GP
Re: E1 G703 problem
Yes I double checked, Im running the following:
12.2(8)T5
215
