E1 PRI Interface - multilink or not
hi,
i have two cisco router , each of them with a e1 pri interface , which i want to
connect over a telco cloud for backup.
i have 30 b-channels which i can use.
if the two router connect, do they automaticly use all 30 b channels or have i to
specify "dialer load-threshold xy" - as it is with bri-int when i want to use the
two b-channels.
thanks for help !
1 REPLY
Re: E1 PRI Interface - multilink or not
You should be able to configure ppp multilink to do this automatically. Otherwise, "dialer-load threshold 1" should bundle them all (depending on IOS release i think). If that doesn't work, then use a really high "dialer idle-timeout" value to keep them all bundled.
D.
207
