E1 vs 2meg serial port
What is the difference between the speed of an e1 port and a 2meg serial port
Re: E1 vs 2meg serial port
I don't think there's any difference, both of them support the speed of 2.048MBPS.
If you are refering to G703 (E1) then you will get 2048kb through as it is a "clean pipe" i.e No clocking, but using an actual serial port (db60) then you are recieving clocking from the DCE and hence you will only recieve 1984kb
123
