Webcast-Catalyst9k
Easy Question - How do I set speed on a WIC-1T?
I have been using the bandwidth command, but it appears ineffective. File transfer speeds are consistently about 50kbps regardless of the speed I set using the bandwidth command.
thanks,
3 ACCEPTED SOLUTIONS
Bronze
Re: Easy Question - How do I set speed on a WIC-1T?
On the router with the DCE end of the cable, enter the interface command "clock rate x", with x being bits per second. If you don't know which end is the DCE, enter the command "show controllers serial (x/y)" and look for the line telling the type of cable that is attached.
Mark
Just use the command clockrate xxxxx on the serial interface.
You must set the clockrate at the router with the DCE cable attached
Silver
The speed of the circuit will be the speed you set your clock
Silver
What exactly do you mean by setting the speed ?
The speed of your circuit depends on what you are buying from your service provider
Good point, I should clarify more.
I have setup a test WAN network in my office with two routers (a spare 2621 and 1721) each with a WIC-1T card installed. Connected with the appropriate V35 cables. I expected to be able to modify the speed of the connection anywhere from 64k up to 3mbit to test application response times across a "slow" connection.
Does this help?
Does this help?
Silver
Are you connecting via back to back DTE-DCE cables ?
I beleivre the max in a T1 wic is going to be T1 not 3 Mb
Yes, I am connecting the two with CAB-V35MT (DTE) and CAB-V35FC (DCE) cables.
You are right about the speed, I was just spewing that as an example. Up to 1.5mb is fine, if I could get it to work.
Bronze
Mark
Silver
214
