Eigrp and Frame Relay
I am setting up full-mesh frame relay network ( 3 locations) with 1 -2650xm and two 1760v routers.
Question about the subnets on the routers. I have configured subinterfaces (point-to-point) on ea router. I plan to use eigrp.
Do each of the subinterface connections need to be in there own subnet when using eigrp? ie: sudinterface1: router a to router b,
sub interface 2 : router a to router c,
subinterface (remote routers) router b to router c,
Or should all serial interfaces be in the same subnet ?
Should I consider rip instead of eigrp ? for such a small network ?
Bandwidth 512k (at ea of the three locations)
Thank You in Advance
John
1 REPLY
Re: Eigrp and Frame Relay
Since you configured subinterfaces which are p-p, you have to put each p-p link in one subnet (will need 3 in total for the wan). You can use a mask of /30 for each of the subnets, which would have 2 hosts each. THis would save some ip addresses for you.
Another way is to configure each router with a single Multipoint subinterface (instead of 2 p-p interface at each router). THis multipoint subinterface would have 2 pvc terminating .
int s0.100 multipoint
frame-relay interface-dlci 100
frame-relay interface-dlci 101
Now once this multipoint subinterface has been configured, you can put them all in same subnet. which would cons ume 3 ip addresses from a single subnet. You can use a /29 mask for the subnet which has 6 hosts, of which 3 is in use.
YOu can configure EIGRP in this network, without running into issues with Split horizon, since you have a full mesh network.
You can even run RIP in this case.
126
