EIGRP and Minimum Bandwidth
I have a 2650 router with Frame-Relay subinterfaces running 12.2.8-T(4).
The network topology is basically a triangle. The router at the TOP has a 512k link to the router on the LEFT and a 228k link to the router on the RIGHT. The LEFT and RIGHT routers have a 128k link between them with an ip range 192.168.1.32/30. When I do a "show ip route 192.168.1.32 from the TOP router it shows me that it has an equal cost route to the subnet.
" Routing Descriptor Blocks:
192.168.1.26, from 192.168.1.26, 10:14:41 ago, via Serial0/0.5
Route metric is 21024000, traffic share count is 1
Total delay is 40000 microseconds, minimum bandwidth is 128 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 37/255, Hops 1
* 192.168.1.6, from 192.168.1.6, 10:14:41 ago, via Serial0/0.8
Loading 6/255, Hops 1"
The Minimum Bandwidth is 128k for both links but there are bandwidth statements configured on the subinterfaces? Why is EIGRP looking at the minimum bandwidth?
Re: EIGRP and Minimum Bandwidth
Could you please copy the relevant configuration bits and show ip route? Also the IP addresses of each link would be useful.
These are the configs on the TOP router:
interface Serial0/0.5 point-to-point
description Link to RIGHT
bandwidth 288
ip address 192.168.1.25 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 103
interface Serial0/0.8 point-to-point
description link to LEFT
bandwidth 512
ip address 192.168.1.5 255.255.255.252
ip nat inside
no ip mroute-cache
frame-relay interface-dlci 112
router eigrp 2000
redistribute static
network 172.16.0.0
network 172.20.0.0
network 172.22.0.0
network 192.168.1.0
no auto-summary
no eigrp log-neighbor-changes
Routing entry for 192.168.1.32/30
Known via "eigrp 2000", distance 90, metric 21024000, type internal
Redistributing via eigrp 2000
Last update from 192.168.1.6 on Serial0/0.8, 00:58:05 ago
* 192.168.1.26, from 192.168.1.26, 00:58:05 ago, via Serial0/0.5
192.168.1.6, from 192.168.1.6, 00:58:05 ago, via Serial0/0.8
UNF-ZA-CORE-C01 uptime is 7 weeks, 17 hours, 23 minutes
System image file is "flash:c2600-ik8o3s-mz.122-8.T4.bin"
cisco 2650 (MPC860P) processor (revision 0x200) with 61440K/4096K bytes of memory.
Processor board ID JAB05390AQK (2310698408)
M860 processor: part number 5, mask 2
The ip addresses of the links are 192.168.1.33 on the LEFT router connecting to the RIGHT router and the ip on the right side is 192.168.1.34.
The network has been added been added under all the eigrps and the bandwidth statements are all correct...
Anything else?
Gold
EIGRP always uses the minimum bandwidth in the path, which is why you should not use bandwidth to engineer traffic in EIGRP--you should use delay instead.
Russ
Hi Russ.
I agree that using Bandwidth statements to influence traffic is not the way and Delays are what you should use. But in this case the bandwidth statements are a true reflection of the network. So how is the Minimum Bandwidth calculated on the interface? Why would a 288k and a 512k have the same Minimum Bandwidths?
the minimum bandowidth of 128 you get in the output is the bandwidth of the direct link between the two routers. EIGRP uses this bandwidth too in its calulations.
Yanna
289
