You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
eigrp authentication problem
i have 4 routers with eigrp
5300 (12.3(1)) 5350(12.3(1)) 3640 (12.1(11)) 7206 (12.1(7b))
all in one subnet on fastethernet
when i enable eigrp authentication all routers except 7206 - OK
7206 up and after 10 sec down
in debug i see that after some time 7206 lost connectivity due to auth failure
also if i connect to 7206 thru 802.1q subinterface by another router and enable authentication everything - OK
  • Other Network Infrastructure Subjects
Re: eigrp authentication problem
This is a common problem..
Remove the key-chain you have created and configure it again one by one. DON'T USE COPY AND PASTE FROM ANOTHER ROUTER OR THROUGH NOTEPAD.
Try this out and let me know how it goes.
Thank You for advise ( i removed keys from all routers and enter them manually again) but it did`t help
eigrp sessions up but after resets
94
