For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
EIGRP authentication using MD5
I need to implement EIGRP authentication between routers and I have a document called "Configuring EIGRP" which has one page called 'Route Authentication Example'.
Is there a more thorough document describing this, one that explains all the different parameters?
In the one I have it just gives the router config examle with no explaination of the 'accept-lifetime', 'send-lifetime' statements. When I use this config in a lab, routing breaks and I have no way to know why. I need to know if I even need the 'accept-lifetime' or 'send-lifetime' statements, if they are optional, what they mean, etc.
Here is the example given that offers no explaination as to why the time and date were given:
Key chain holly
key-string 0987654321
accept-lifetime 04:00:00 Dec 4 1996 indinite
send-lifetime 04:00:00 Dec 4 1996 04:48:00 Dec 4 1996
Thanks.
  • Other Network Infrastructure Subjects
1 ACCEPTED SOLUTION
Re: EIGRP authentication using MD5
HI Friend,
These are optional commands first of all
accept-lifetime ---> Optionally specify the time period during which the key can be received.
send-lifetime ---> Optionally specify the time period during which the key can be sent
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_c/1cprt1/1ceigrp.htm#wp4759
To know more about these and its usage guide lines please check this links
for accept-liftime command
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_r/1rprt1/1rindep.htm#wp1017389
for send-lifetime command
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/12cgcr/np1_r/1rprt1/1rindep.htm#wp1020195
Ankur
1 REPLY
HI Friend,
Ankur
98
