EIGRP in a NBMA hub and spoke configuration ?
Is there a way to configure EIGRP for a Frame Relay NBMA network using a hub and spoke topology ?
I'm curious that I cannot find any config examples for this, whereas with OSPF in this environment there are plenty of examples.
I'm wondering if EIGRP being a distance-vector protocol this shouldn't be attempted.
PS: I've been at this all day and have only managed to get EIGRP to work in one cofiguration and that was using physical interfaces on all routers and switching off split horizon at the hub router. I used frame-relay map statements with broadcast enabled also.
Any pointers would be appreciated.
Cheers,
Phil.
Re: EIGRP in a NBMA hub and spoke configuration ?
Phil,
Can youfurnish configs? Here is a link that should help on EIGRP configuration.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d97f8.html
Please rate if post helps
hi phil,,,
here is the configuration for the HUB router
! hostname ABC
interface Ethernet1
ip address 192.168.2.1 255.255.255.0
interface Serial0
no ip address
encapsulation frame relay
no ip mroute cache
interface Serial0.1 multipoint
no ip split horizon eigrp 2001 Split Horizons disabled
bandwidth 112 Bandwidth set to the sum of the remote PVCs
frame relay map ip 192.168.1.5 110 broadcast
frame relay map ip 192.168.1.6 130 broadcast
router eigrp 2001 EIGRP routing process
network 192.168.1.0 Networks running EIGRP
you can have appropriate IP addressing as per your design...
you can have some easy configuration at spoke side with compere to HUB router....
regards
Devang
Hall of Fame Super Silver
Phil
I believe that there are not as many examples about EIGRP NBMA as there are OSPF because EIGRP does not have nearly as many knobs to tweak to accomplish this as OSPF does.
You should be able to do this with physical interfaces as you mentioned or with multipoint subinterfaces as Devang shows. They should both work. The essential aspect of this is that you must disable split horizon on the hub. And of course you need to be careful with the frame relay maps to be sure that you get the right connectivity (especially hub to hub).
While I believe that Frame Relay NBMA is never the optimum solution you should be able to get it to work with both OPF and with EIGRP.
Rick
384
