Community Member
eigrp neighbour state changes - monitoring
Is it possible to monitor eigrp neighbour state change via SNMP or and SNMP traps?
Re: eigrp neighbour state changes - monitoring
I have seen one for BGP state change traps. Havent seen any for EIGRP neighbor related SNMP traps. You can log neighbor state change information in a syslog server.
Enabling logging first to a syslog server, using,
logging x.x.x.x , where x.x.x.x is the syslog server ip.
router eigrp 45
eigrp log-neighbor-changes
eigrp log-neighbor-warnings
Community Member
This is the best way I have done it. Log all messages to a syslog server(pref a UNIX box) then run this command:
tail -f syslog.log | grep -i eigrp neighbor(whatever your looking for) > email@email.com
This parses though the syslog file seraching for the keyword eigrp or neighbor and sends data through email.
Hope this helps.
Syslog is your friend!
Stephen
707
