EIGRP on Group Asyc. interface
hi,
I have EIGRP runing on Access server and I don't want each dail-up user to advertise its ip add. in the routing table of the backbone router
My problem is that I got the following
In backbone router tables
D 10.5.1.23/32 [90/24823296] via 10.254.254.10, 00:01:12, ATM3/1/ima1
AND
In the Access server routing table
C 10.5.1.23/32 is directly connected, Async205
So , I will have entry for each dail-up user in the backbone routing table !!!!
My access server config. is :
interface Loopback0
ip address 10.5.1.1 255.255.255.0
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
ip tcp header-compression passive
async mode interactive
peer default ip address pool analog
ppp authentication chap pap
group-range 161 190
router eigrp 1
network 10.0.0.0
auto-summary
no eigrp log-neighbor-changes
ip local pool analog 10.5.1.2 10.5.1.61
How can I solve this problem ?
'Thanks
Mohamed Abdallah
Re: EIGRP on Group Asyc. interface
I assume your backbone router is connected to your access server on the fast ethernet or ethernet interface. On this interface of the access server, put a command on the interface mode.
(config)#interface fa0/0 (or interface e0/0 or interface e0)
(config-if)#ip summary-address eigrp 1 10.5.1.0 255.255.255.0
This will summarize all the host routes and send it as a single route to the backbone. WHen you enter this command, there would be a 10.5.1.0 /24 route on your routing table pointing to null0.
Hope this will help.
Thanks for your help
my backbone is connected to the access server using ATM interface ( point to point PVC )
here is my access server config.
interface Loopback0
interface FastEthernet0/0
ip address 10.5.10.254 255.255.255.0
speed auto
full-duplex
interface ATM1/0
no ip address
atm vc-per-vp 256
no atm ilmi-keepalive
ima-group 0
scrambling-payload
impedance 120-ohm
interface ATM1/IMA0
description E1 link to Backbone Router
ip address 10.254.254.10 255.255.255.252
atm vc-per-vp 256
pvc 2/35
protocol ip 10.254.254.9 broadcast
encapsulation ppp
group-range 161 190
router eigrp 1
network 10.0.0.0
auto-summary
line 161 190
modem InOut
autocommand ppp
transport input all
autoselect during-login
autoselect ppp
Should I enter the command "ip summary-address eigrp 1 10.5.1.0 255.255.255.0 "on the IMA group interface ?
should I disable the auto summary on EIGRP process on access server
using no auto summary command ?
Mohamed
Hi Mohammed,
You have to configure this command on the IMA group interface.
Looking at your ip address pool, I would suggest you to summarize the network to a more specific network address. Since you have only 60 address in the pool, it would be much better to get summarized into a network with 64 hosts addresses, rather than to be summarized into a network with 254 addresses (10.1.5.0/24 would have 254 host addresses in it)
In summary, the summary command would look like,
ip summary-address eigrp 1 10.5.1.0 255.255.255.192 (this would summarize to a network 10.5.1.0/26 - with 64 host in it)
107
