EIGRP PROBLEM - NOVELL SERVER
When we migrated from rip to Eigrp we found the
netware servers in branches were not able to reach the central office.
The netware server is reachable within the local net.
Netware server runs 3.12 and is bound to ip
with frame type ETHERNET_II
With rip this is not a problem.
ipx routing is not enabled.(either when in rip or in eigrp now)
what is the issue.
VIP Purple
Re: EIGRP PROBLEM - NOVELL SERVER
hard to say...can you post the configuration of the relevant routers ?
GP
azj
Do a search on the words cisco novell eigrp on google or something, I remember this comming up a while ago, Ill let you know if I find the post.
Ta
AJ
(CCNA, Cisco Academy Instructor Trained)
By default the IP stack for Netware 3.x listens for RIP. You can disable this feature and configure a default gateway but you will have to edit the 'startup.ncf' file. Have a look on Novell's website for the exact syntax - its been years since I touched it, but I specifically remember this issue.
Try this page on Novell's site - since you have netware 3.12 it may not have all the info you need:
http://support.novell.com/cgi-bin/search/searchtid.cgi?/10013002.htm
Andy
Hello
There looks like that there is routing problem. You need to enable ipx routing on the local routers in the remote branches. Have RIP and EIGRP running on the routers. And disable rip advertisement on the specific ipx network. By default redistribution is enabled between rip and eigrp.
This should solve your problem.
Agnelo
98
