eigrp redistribute problem
router_a------router_b
If I config on the router_a:
conf t
ip route 137.1.1.96 255.255.255.224 192.168.1.2
ip route 6.0.0.0 255.128.0.0 null 0
ip route 6.128.0.0 255.128.0.0 null 0
router eigrp 1
redis static route-map stat-e1
route-map stat-e1 permit 10
match ip addr 13
no access-list 13
access-list 13 permit 6.0.0.0
access-list 13 permit 6.128.0.0
access-list 13 permit 137.1.1.96
end
the static route will not redistribute into eigrp as 1,
But if I config like this(cofnig static route at last):
conf t
router eigrp 1
match ip addr 13
no access-list 13
end
everything will ok,why? If I use prefix-list to replace access-list, there is same result.
Are there any bug? Look like IOS will process redistribute correctly only if you config
static route at last. I can't find anything using bug toolkit.
And if I show ip route on router_b
router_b#show ip route
D 6.0.0.0/9 [90/28160] via 192.168.8.253, 01:59:55, FastEthernet1/0/0
D 6.128.0.0/9 [90/28160] via 192.168.8.253, 01:59:55, FastEthernet1/0/0
D EX 137.1.1.96/27 [170/28416] via 192.168.8.253, 01:59:56, FastEthernet1/0/0
Why 6.0.0.0/9 and 6.128.0.0/9 is internal route and 137.1.1.96/27 is external route?
Is it because 6.0.0.0/9 and 6.128.0.0/9 is point to null 0?
Re: eigrp redistribute problem
They should all be external. Not sure why, I did the same and it worked for me:
Router#config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#ip route 137.1.1.96 255.255.255.224 192.168.1.2
Router(config)#ip route 6.0.0.0 255.128.0.0 null 0
Router(config)#ip route 6.128.0.0 255.128.0.0 null 0
Router(config)#router eigrp 1
Router(config-router)#redis static route-map stat-e1
Router(config-router)#net 192.168.1.0
Router(config-router)#no auto
Router(config-router)#exit
Router(config)#route-map stat-e1 permit 10
Router(config-route-map)#match ip addr 13
Router(config-route-map)#exit
Router(config)#access-list 13 permit 6.0.0.0
Router(config)#access-list 13 permit 6.128.0.0
Router(config)#access-list 13 permit 137.1.1.96
Router(config)#
Router(config)#^Z
Router#sh ip
00:42:15: %SYS-5-CONFIG_I: Configured from console by console rout
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
U - per-user static route, o - ODR
Gateway of last resort is not set
137.1.0.0/27 is subnetted, 1 subnets
S 137.1.1.96 [1/0] via 192.168.1.2
6.0.0.0/9 is subnetted, 2 subnets
S 6.0.0.0 is directly connected, Null0
S 6.128.0.0 is directly connected, Null0
C 192.168.1.0/24 is directly connected, Serial0
Router#
Router2#config t
Router2(config)#int s0
Router2(config-if)#ip add 192.168.1.101 255.255.255.0
Router2(config-if)#router eigrp 1
Router2(config-router)#net 192.168.1.0
Router2(config-router)#no auto
Router2(config-router)#^Z
Router2#sh ip ei ne
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 192.168.1.100 Se0 11 00:00:04 452 2712 0 1
Router2#sh ip rout
D EX 137.1.1.96 [170/2681856] via 192.168.1.100, 00:00:06, Serial0
D EX 6.0.0.0 [170/2169856] via 192.168.1.100, 00:00:07, Serial0
D EX 6.128.0.0 [170/2169856] via 192.168.1.100, 00:00:07, Serial0
Router2#
What does your eigrp top look like (something like below):
Router#sh ip ei top
IP-EIGRP Topology Table for process 1
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - Reply status
P 6.0.0.0/9, 1 successors, FD is 256
via Redistributed (256/0)
P 192.168.1.0/24, 1 successors, FD is 2169856
via Connected, Serial0
P 6.128.0.0/9, 1 successors, FD is 256
P 137.1.1.96/27, 1 successors, FD is 2169856
via Redistributed (2169856/0)
Router#sh ip rout 6.0.0.0 255.128.0.0
Routing entry for 6.0.0.0/9
Known via "static", distance 1, metric 0 (connected)
Redistributing via eigrp 1
Advertised by eigrp 1 route-map stat-e1
Routing Descriptor Blocks:
* directly connected, via Null0
Route metric is 0, traffic share count is 1
Router2#sh ip ei top
r - Reply status
P 6.0.0.0/9, 1 successors, FD is 2169856
via 192.168.1.100 (2169856/256), Serial0
P 6.128.0.0/9, 1 successors, FD is 2169856
P 137.1.1.96/27, 1 successors, FD is 2681856
via 192.168.1.100 (2681856/2169856), Serial0
Router2#sh ip route 6.0.0.0 255.128.0.0
Known via "eigrp 1", distance 170, metric 2169856, type external
Last update from 192.168.1.100 on Serial0, 00:08:50 ago
* 192.168.1.100, from 192.168.1.100, 00:08:50 ago, via Serial0
Route metric is 2169856, traffic share count is 1
Total delay is 20000 microseconds, minimum bandwidth is 1544 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1
What IOS are you running? If possible I would clear the config, reload and re-enter the config. If you can't can you post the show output like above?
Steve
Steve,
thanks,I can't clear the config because the router is in production.But I test it on a new 2611,result is same.I don't know why,maybe your IOS is different with mine and different IOS has different behavior.
2611#sh ip eigrp to 6.0.0.0 255.128.0.0
IP-EIGRP topology entry for 6.0.0.0/9
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 256
0.0.0.0, from Rstatic, Send flag is 0x0
Composite metric is (256/0), Route is Internal
Vector metric:
Minimum bandwidth is 10000000 Kbit
Total delay is 0 microseconds
Reliability is 0/255
Load is 0/255
Minimum MTU is 1500
Hop count is 0
2611#sh run
Building configuration...
Current configuration : 1825 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname 2611
router eigrp 10
redistribute static route-map stat-e10-access-list
network 6.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 6.0.0.0 255.128.0.0 Null0
ip route 6.128.0.0 255.128.0.0 Null0
no ip http server
access-list 183 permit ip host 6.0.0.0 host 255.128.0.0
route-map stat-e10-access-list permit 10
match ip address 183
end
2611#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(5)T9, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sun 24-Jun-01 03:16 by cmong
Image text-base: 0x80008088, data-base: 0x8101A744
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
2611 uptime is 16 weeks, 1 day, 18 hours, 29 minutes
System image file is "flash:c2600-is-mz.121-5.T9.bin"
cisco 2611 (MPC860) processor (revision 0x300) with 45056K/4096K bytes of memory
Processor board ID JAD06070DPW (310835556)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
router_a>sh ip eigrp to 1
IP-EIGRP Topology Table for AS(1)/ID(6.1.99.200)
r - Reply status
via Rstatic (256/0)
via Rstatic (256/0)
P 137.1.1.96/32, 1 successors, FD is 2816
via Rstatic (2816/0)
router_a>sh ip route 6.0.0.0 255.128.0.0
Redistributing via eigrp 1, eigrp 18
Advertised by eigrp 1 route-map stat-e7
router_a>sh ver
IOS (tm) MSFC2 Software (C6MSFC2-IS-M), Version 12.1(2)E, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 19-Jun-00 22:17 by linda
router_b>sh ip eigrp to
IP-EIGRP Topology Table for AS(1)/ID(10.1.126.37)
r - Reply status
P 6.0.0.0/9, 4 successors, FD is 28160
via 192.168.8.253 (28160/256), FastEthernet1/0/0
P 137.1.1.96/27, 4 successors, FD is 28160
via 192.168.8.253 (28416/2816), FastEthernet1/0/0
P 6.128.0.0/9, 4 successors, FD is 28160
router_b>sh ip route 6.0.0.0 255.128.0.0
Known via "eigrp 1", distance 90, metric 28160, type internal
Last update from 192.168.8.253 on FastEthernet1/0/0, 20:37:59 ago
192.168.8.253, from 192.168.8.253, 20:37:59 ago, via FastEthernet1/0/0
Route metric is 28160, traffic share count is 1
Total delay is 100 microseconds, minimum bandwidth is 100000 Kbit
Loading 2/255, Hops 1
router_b>sh ip route 137.1.1.96 255.255.255.224
Routing entry for 137.1.1.96/27
Known via "eigrp 7", distance 170, metric 28416, type external
Redistributing via eigrp 7
Last update from 10.1.96.254 on FastEthernet1/0/0, 20:44:10 ago
* 192.168.8.253, from 192.168.8.253, 20:44:10 ago, via FastEthernet1/0/0
Route metric is 28416, traffic share count is 1
Total delay is 110 microseconds, minimum bandwidth is 100000 Kbit
Steve,
I upgrade my 26'IOS to 12.1(18),result is same(route which point to null 0 is still internal).
can u tell me what's your IOS version?
regards
Henry
It is a lab router so the IOS is older - 12.0(21):
router#sh ver
IOS (tm) 2500 Software (C2500-D-L), Version 12.0(21), RELEASE SOFTWARE (fc1)
Compiled Mon 31-Dec-01 18:25 by nmasa
Image text-base: 0x03038AE4, data-base: 0x00001000
ROM: System Bootstrap, Version 4.14(9.1), SOFTWARE
router uptime is 54 minutes
System restarted by power-on at 09:30:52 UTC Fri Feb 14 2003
System image file is "flash:c2500-d-l.120-21.bin"
cisco 2509 (68030) processor (revision B) with 16384K/2048K bytes of memory.
Processor board ID 49356531, with hardware revision 00000000
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
8192K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2142
router#
Router_a is learning 6.0.0.0/9 via eigrp 1 and eigrp 18. Can you post the full config (minus IPs/passwds)? What does the network topology look like?
How many peers does router_b have as each route has 4 successors? The external route was learned via eigrp 7 (update from 10.1.96.254) and has a metric of 28416 and the internal routes learned from eigrp 1 (peer 192.168.8.253) with a metric of 28160.
Steve
Steve,
I download 12.0(21) to my 2600,route is internal,too.I think it is too detail.I don't want waste your time to invesgiate this problem.Thanks!
2600#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(21), RELEASE SOFTWARE (fc1)
Compiled Mon 31-Dec-01 20:22 by nmasa
Image text-base: 0x80008088, data-base: 0x808FA3E4
ROM: C2600 Software (C2600-IS-M), Version 12.1(18), RELEASE SOFTWARE (fc1)
r26hqct02 uptime is 8 minutes
System restarted by reload
System image file is "flash:c2600-is-mz.120-21.bin"
cisco 2611 (MPC860) processor (revision 0x300) with 39936K/9216K bytes of memory
Bridging software.
2600#sh ip eigrp to 6.0.0.0 255.128.0.0
0.0.0.0, from Redistributed, Send flag is 0x0
Vector metric:
Load is 0/255
Minimum MTU is 1500
Hop count is 0
2600#sh run
router eigrp 10
network 6.0.0.0
network 9.0.0.0
no auto-summary
ip classless
ip route 5.0.0.0 255.0.0.0 Null0
ip route 6.0.0.0 255.0.0.0 Null0
ip route 6.0.128.0 255.255.128.0 Null0
ip route 7.0.0.0 255.0.0.0 10.0.24.253
ip route 7.0.0.0 255.128.0.0 Null0
ip route 8.0.0.0 255.0.0.0 Null0
ip route 9.0.0.0 255.0.0.0 Null0
access-list 183 permit ip host 6.128.0.0 host 255.128.0.0
access-list 183 permit ip host 7.0.0.0 host 255.0.0.0
access-list 183 permit ip host 8.0.0.0 host 255.0.0.0
access-list 183 permit ip host 5.0.0.0 host 255.0.0.0
141
