08-27-2003 07:49 AM - edited 03-02-2019 09:55 AM
I have a Distribution router running EIGRP and all remote routers off this distribution router are using static routes (no EIGRP). Will I see any EIGRP traffic in the link (this case Frame Relay) between the distribution router and the remote router?
08-27-2003 08:08 AM
not unless you have EIGRP enabled with a network statement on the access routers
08-27-2003 11:02 AM
OK Thanks for confirming that. I have to fix my network monitor.
Gilson
08-27-2003 11:04 AM
Hmm.... If you have the interface facing the remotes covered under a network statement in EIGRP, the deistibution router is going to send hello's out to each of the remotes, even if they aren't running EIGRP. If you want to cut these out, then you could run the interface that connects to the remotes as a passive interface, or not cover the interface with a network statement.
Russ.W
08-27-2003 12:14 PM
It make sense but I will have to apply "passive interface" on many Frame subinterfaces or I will have to change the ip address scheem to have the subinterfaces out of the EIGRP.
Gilson
08-27-2003 12:30 PM
Not really.... You have several options here. In more recent code, you should be able to do:
passive-interface default
no passive-interface xxxxx
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a008008784e.html
So, you can list just the interfaces you don't want to be passive. Another option is to be creative wih the wildcard bits on the network statements under eigrp. For instance, if you have:
E0 10.1.1.0/24
E1 10.1.2.0/24
S1.1 10.1.3.0/31
S1.2 10.1.3.2/31
S1.3 10.1.3.4/31
You can use:
router eigrp 100
network 10.1.1.0 0.0.0.255
network 10.1.2.0 0.0.0.255
You can cover just a specific interface like this:
router eigrp 100
network 10.1.1.1 0.0.0.0
network 10.1.2.1 0.0.0.0
Which would still catch just the ethernets above, if they are on the .1 addresses.
Russ.W
08-28-2003 04:14 AM
Thank You Russ.
Now it makes more sense. I will apply that and let you know the results.
Gilson
